Signal Conditioning
Magnetic Encoder / ABS Sensor
I want to take measurements from an ABS sensor, which I will use as a shaft encoder.
As my device is a two wire device, I'm assuming that it is a 'variable reluctance' type.
I'm looking for advice as to which NI card I should use to make these measurements. Bench tests seem to indicate that the voltage generated by the sensor is in the millivolt range, which makes me wonder if I should use a thermocouple unit!
Has anyone taken measurements from an ABS sensor using NI hardware before?
Dan
(6,452 Views)
If it is a varialble reluctance type sensor you migth get increasing voltages with increasing speed. Did you do your bench test with similar speeds? Did you use a scope or a multimeter?
Thermocouple inputs often have low pass filters ... not usefull in your case.
What is the expected frequency range?
For a quick and dirty test you can try the soundcard ( ! AT OWN RISK ! )
Soundcard input protection
The attached vi is untested !
For industrial use a real DAQ , depending on other values you want to measure.
Greetings from Germany
Henrik
LV since v3.1
(6,443 Views)
Hi Doneill
There's a good article on this type of application: Using a Magnetic Encoder in an Anti-Lock Braking Application
Kind Regards
Chris | Applications Engineer NIUK
(6,427 Views)
