Signal Conditioning
MY first program in LabVIEW, please check it
This is my first LabVIEW , My program is about taking EEG signal and filter it and extrat theta and alpha waves
please could anyone  check my program
(4,745 Views)
Your best bet is to post this on the LabVIEW message board.
(4,736 Views)
So I would arrange all of the vis so that you minimize the number of bends in wires. Also consider using subvis when you have portions of code preforming the same operations. It looks like you extract a portion of your code and then do some statistics on that portion. Consider making a subvi that you can resue. Also check out the following
Chris C
(4,723 Views)
Thank u
(4,717 Views)
Also look at LabVIEW Style guide
(4,695 Views)
After using Extract portion of signal , how  I can use the boolean ?
I mean how I make the light to turn on?
(4,678 Views)
One method:
Since the signal would have a numeric attribute, You could compare this with a numeric value and use the output of 'comparison' operation to make an LED glow. You will find comparison functions in Functions palette>> comparison
Look at attached pic
(4,673 Views)
