Signal Conditioning
LVDT position sensor and NI cDAQ
Hi
Is there any good way to use LVDT sensor and NI cDAQ system? The sensor is used for a high precision position measurement, the total displacement is just about 10 micro meter.
What NI cDAQ module would be good and do we need an external signal condition module? Can you recommend some? The sensors we can find..
BR,
Ilkka
(1,279 Views)
Only PXI based cards are available for LVDT in NI's portfolio. https://www.ni.com/en-us/shop/category/position-displacement.html
Usually the LVDT manufacturer also offers signal conditioner/amplifiers. Here are some that I found on Google,
https://www.futek.com/store/instruments/usb/mv-v-amplified-and-encoder-input-usb-solution-USB520
https://www.rdpe.com/us/e749l.htm
https://www.te.com/usa-en/products/sensors/position-sensors/signal-conditioners.html?tab=pgp-story
https://www.omega.com/en-us/data-acquisition/signal-conditioners/specialty-conditioners/ldx-4-lvdt-s...
Santhosh
Soliton Technologies
(1,258 Views)
Hi Santhosh,
Thank you very much for the links. I also conducted a search before, but I didn't notice all the links you provided.
The PXI-based solution would be a little too expensive and complicated to maintain. We will use the NI cDAQ-9189 chassis, so the only option is to use third-party signal conditioning.
Best regards, Ilkka
(1,212 Views)
