Signal Conditioning
I challenge NI to show us a impedance matched 1m RDIO-68 - 7811R digital driver for a 10MHZ TTL signal
NI advertises the RDIO 68 cable for high speed digital interface to R series PXI boards such as the 7811R.  The unpublished impedance of the RDIO was given to me
as ~90 ohms however the details of the termination network used (which is embedded in the RDIO cable end) are not available.  My question is:
1.  Why does NI suggest this cable for high speed interface but does not provide the required information to design a matched drive signal that will minimize ringing and signal reflection?
I have tried a variety of techniques using series terminations, HC and LS line drivers but cannot do any better than the attached scope trace which reveals a significant signal reflection.
(5,570 Views)
Hi Sachsm,
You posted the same question on the following forum.
 http://forums.ni.com/t5/Real-Time-Measurement-and/I-challenge-NI-to-show-us-a-impedance-matched-1m-R...
I am going to be working with you on that thread.
Josh
(5,533 Views)
