Signal Conditioning
How to properly ground temeprature sensor
I recently bought an Iduino SE029 Temperature sensor and I am planning to connect it with an NI USB 6211 DAQ device and power it from a signal generator acting as a DC source. The sensor has three pins: ground, power and data. Should I connect the ground pin to the power negative cable or to one of the  DAQ-device digital inputs?
Thank you
(2,882 Views)
definately NOT to a digital input! You should connect it to the power negative cable AND one of USB-6211 DGND pins. By the way USB-6211 also has a 5V output, so you wouldn't need the external power supply.
As far as I see from the sensor's specs it provides you a the temperature in digital format (12bit). Means you have to perform a digital input task and analyze the bits (Data->DigIN Pin). There are some obstacles if you plan to do so. E.g. there is no HW clock connected directly to the digital inputs so you have to do something like this:
Correlated DIO with USB M Series DAQ Device - National Instruments
http://digital.ni.com/public.nsf/allkb/D34BEC815E400ECD8625768A006F8AD6
Afterwards you also have to find the start of a transmission and alnalyse the bits.
What you plan to do is possible but in my opinion you shoud reconsider your choice of temperature sensor and by one which delivers you a to the temperature proportionl voltage, then spimply perform an analogue input task...
Hope I could help you
Heinz
(2,848 Views)
