Signal Conditioning
How do I access my SCXI-1127 with RDA?
I have a PXI-1010 Chassis with a NI-4060 card in slot 8 and an SCXI-1127 in slot 4. The SCXI is controled with the internal bus. My question is, Can I use NI-SWITCH over RDA to control the SCXI-1127?
(3,733 Views)
Dear Sir,
Thank you very much for using the Developer Exchange.
At this time it is not possible to use the NI-1127 over RDA. What you can do though is to run the VI remotely using VI server. This way you can develop your application using NI-switch in the remote machine and then control the execution remotely using VI server or via TCP/IP if you are using other programming language than LabVIEW.
Best Regards.
Omar De Andrade
Applications Engineer - Computer Based Instruments
http://www.ni.com/support/
(3,733 Views)
