Signal Conditioning
How can you activate the Anti-Aliasing filters on the board NI PCI 6120
How can you activate the Anti-Aliasing filters on the board NI PCI 6120. Can this be done using Measurement and Automation Explorer.
Thanks.
Message 1 of 10
(8,329 Views)
Hi Myali123,
From the 6120 User Manual:
Kyle A.
Senior Applications Engineer
Message 2 of 10
(8,309 Views)
How do I get to NI-DAQ to use AI_Change_Parameter function. Please clarify. Is there a way to change the fliter settings through measurment and automation explorer
Message 3 of 10
(8,302 Views)
Sorry about that, here is what I found from MAX once a task is created:
Kyle A.
Message 4 of 10
(8,300 Views)
I am able to create a task but I am not getting the device tab as in your screen shot..please elaborate on the way you arrived at this
Message 5 of 10
(8,295 Views)
Hi Myali,
Are you using Traditional DAQ or DAQmx to access your device?  I simulated a PCI-6120 as a DAQmx device, created an Analog Input Voltage task, and when the configuration loaded that screenshot is what I saw.
Kyle A.
Message 6 of 10
(8,291 Views)
I am using a NI-DAQmx. I am attaching a screen shot. Please explain step by step.
Message 7 of 10
(8,276 Views)
Message 8 of 10
(8,273 Views)
That is an older version of MAX compared to mine, if you update to a more current version you will be able to see what I'm seeing.  This can be done by updating a driver, which will in turn update MAX.  It may be easiest to install the current NI-VISA or another driver that is not critical to your application.  Upgrading NI-DAQmx will do the same as well.
Kyle A.
Message 9 of 10
(8,245 Views)
Hi Myali,
Configuring the NI 6120's filter in the DAQ Assistant requires NI-DAQmx 8.8 or later. Here's a link to the current version of NI-DAQmx: NI-DAQmx 9.2.1.
Brad
Brad Keryan
NI R&D
Message 10 of 10
(8,231 Views)
