Signal Conditioning
How To Turn Off 2 Hz Filter on SCXI- 1102
I would like to measure dynamic signals up to and above 100 Hz using the SCXI- 1102 Module with the 1303 terminal block. Is there a way of turning off the 2 Hz filter(mechanically or with programming. Please Help.
(4,332 Views)
Hi John,
There is no way to programatically or physically disable the filter on your 1102 module. The filters are hard wired into the module on each channel and cannot be bypassed.
Perhaps another module like the 1102B or 1104C might better suit your application.
Sal
(4,329 Views)
how to cut-off the scxi-1102b frequency 100HZ for filter the electrical power noise just like 50HZ/60HZ?
(4,123 Views)
The filters on these cards are fixed.  I talked with an enginneer to see if I could make a physical hardware change to the card and he did not recommend it.  For 50 60 hertz isoltation you can use an external filter or on that NI has for the scxi chassis.  I have used both with great results.
(4,111 Views)
i foud a way via program to cut-off the filter ,that's use property node in fuction pannel at max. i not sure if it's effect.
(4,108 Views)
No that property node will have no effect on the Filter present on the SCXI 1102, since it is a fixed filter
(4,095 Views)
