Signal Conditioning
Cut within specific range
I use MCdaq201 to acquire signal from a photodiode. What I see in oscilloscope, is a beautiful sine wave!,  exactly what I was expecting. Then, I connect  it to the PC via MCdaq-USB201, I see a signal which is  like it has been cut within a specific range. I've attached the screenshot of the output of labview program and tracerDAQ. Does anyone know what could be the reason?
Petar
(6,220 Views)
This has nothing to do with NI signal conditioning hardware. I suggest you post to the measurement computing web site for help with their hardware and software.
(6,204 Views)
Ok, I will. thanks for your reply.
(6,191 Views)
Just some quick hints...
Your DAQ may have a BIAS current, that can do funny things with photo diodes ...
The input impedance of your DAQ and the scope migth be different.....
Greetings from Germany
Henrik
LV since v3.1
(6,172 Views)
Thanks for your reply, but I also connected an external resistor to the photodiode, but,,,,the output is the same :(...without any change
(6,157 Views)
See the DAQ input as a current source, a resistor and a capacitor 😉 (maybe even an inductivity is hidden somewhere... Who knows....)
Try a preamp... And most of the differences should be gone... However, the result will be the output of the preamp, could be the one desired...
Henrik
LV since v3.1
(6,121 Views)
Accepted by topic author Petar2015
Thanks so much for all your helpful advices, YES! We used a pre-amp between the photodiode and the DAQ device, and acquired the desired signal!
And, I'm really HAPPY! 🙂
(6,106 Views)
