Signal Conditioning
Cannot Export NI-DAQmx Task
Just updated to MAX V 4.6 .  Cannot export NI-DAQmx tasks.  I have attached the configuration report.  I have reset the device, the error still lists the device identifier as invalid.
(7,129 Views)
Hello eroberts,
Does your SCXI device show up under Devices and Interfaces>>NI-DAQmx Devices in Measurement and Automation Explorer?  Also, how are you exporting the task and where are you trying to export it to?
(7,115 Views)
The device (an SCXI-1000, with associated SCXI-1600 & SCXI-1520) shows up as listed equipment.  I am trying to export a task as an nce file (NI config export file) to a folder in my documents.  This has worked fine in the past.  The idea is that I would set up a task, and export it for associates to use on their laptops.
(7,100 Views)
It appears the error is sourced from the Device identifier. Can you confirm that all device references(Dev1) in the task are called correctly?
Glenn
Glenn
(7,079 Views)
