using cRIO 9074 with Epos 2
Hello everyone,
I have no experience with motor control and I want to do a DC motor parameter's identification. So basically, its a open loop system and I want to get angular velocity-voltage diagram.
My question is how I can do this test with a maxon DC motor, Epos 2 70/10, an incremental encoder and cRIO 9074 (with no modules). what other modules do I need to set up the expriment? how should I use the cRIO with Epos 2?
Thank you in advance for your help
(3,277 Views)
Looking at the manual for the Epos 2 70/10, it looks like it is a motor controller that communicates using CANopen or Serial. Our typical motion system utilizes a cRIO as a controller. You could still use the cRIO to send CANopen or Serial commands to the Epos 2 70/10.
From what I could tell, the Epos 2 70/10 does not support taking encoder measurements. This is where the cRIO and a DIO module such as the NI 9403
I'm not quite sure what you mean by velocity-voltage diagram, could you please elaborate on that? You may need an Analog Input module as well if you need to read in voltage.
Aaron Douglass
(3,245 Views)
Thank you very much for your response,
actually I want to do an experimental bode diagram, (forget about velocity-voltage diagram). so I want to have sinusoidal voltage with different frequancies as the input and velocity as the output and to be measured.
Is it necessary to use CANopen ?
I dont have much experience and knowledge on this matters and thats why I ask basic questions. thanks.
(3,240 Views)
As Aaron D said, you can use Serial to achieve the communication. CANopen is not the only channel. So a CANopen module is not necessary. However, a DIO module is essential because of the demand of the encoder.
Thanks!
(3,211 Views)
