time precision cRIO
Good afternoon
I will use a CRIO with the Real-Time module with Labview. What is the precision ? I need to have a maximum error of 100 ms on a period of 4 hours.
Simon Michau
(6,266 Views)
Hello Simon,
The precision of the hardware Real-Time clock depends on the model of RIO you're planning to use.  These specifications are available in the Operating Instructions for the respective RIO controllers.
Best Regards,
Tom L.
(6,260 Views)
hello,
Thank you for your answer. I will use the cRIO 9074.
It's written  "Accuracy   200 ppm; 35 ppm at 25 °C". But I don't know what I mean. Is it 200 pulses per minutes, therefore it's a period of 0.3 s...??
Regards
Simon
(6,252 Views)
Oh sorry... It's 200 parts per millions...
But what's the basis of time ?
(6,248 Views)
Hello smichau,
This article elaborates on how to calculate absolute possible system clock drift based on the precision of the onboard oscillator:
KnowledgeBase 4SKHG5C1: What Is the Difference Between System Time Drift and Jitter For a Real-Time CompactRIO Controller and How Does it Affect Synchronization?
http://digital.ni.com/public.nsf/allkb/C1DCC95927F9C4CD86257526006FA720
If you have a hard requirement of less than 600 ms of drift per day, you'll likely either need to resynchronize the RIO with a high-precision external timebase via 1588 or similar protocol at intervals or use a RIO with a more precise clock, such as the 9068.
Best Regards,
Tom L.
(6,239 Views)
Hello.
Thank you verry much. I also asked to a representative of NI. 200 ppm, it's 200us for 1 s, so 3.88 s for 4h !
Therefore I will resynchronize the RIO. I will use the GPS module I think.
Thank you verry much !
Best regards
Simon M.
(6,228 Views)
