pwm m series or x series
greets
is it possible to generate a 20Khz PWM with resolution of 12bits in the X series Data acquisition or in M series Data Acquisition?
best regards
(3,161 Views)
Are you talking about an analog or a digital PWM?
If you want to create a digital PWM, then the resolution is not important and a M Series board like PCI-6221 can create a PWM output signal with 20 KHz because its Digital Output Max Clock Rate is 1 MHz.
If you want to create an analog PWM, then you can also use a PCI-6221 M Series board that has a resolution of 16 bits and an output Update Rate of 833 KS/s.
Here is the link for the PCI-6221:
https://www.ni.com/en-us/support/model.pci-6221.html
Please let me know if you have any doubt.
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(3,100 Views)
