photon counting and synchronization with raster scanning
Guys, Need some serious help. I am using the attached vi for photon counting with SPCM AQRH 13  model photon counting module with a 6032E daq and 2110 BNC connector block. This vi works for me when I keep running more than one channel and dwell time greater than 5 msec. However this runs only in continuous mode. I tried finite sample and it errored. I need it for imaging purpose where I am raster scanning the sample using a xy stage. I need it to be synchronized with the stage. So that it counts photon for the given dwell time when the detector is fixed at a particular pixel. Stops and then begins again when the stage moves to a new pixel.
I also need help with the data saving.
Thank you
(2,659 Views)
Finite sampling will use a slightly different structure than the continuous sampling. A good place to start is the example programs found in LabVIEW.
Help >> Find examples>>Browse >> Hardware Input and Output >> DAQmx
There are examples in this folder for both continuous and finite samples. You can also find good examples for writing data files in the example finder
Matthew C.
NI | AE
(2,616 Views)
