number of files stored into a cRio
Hallo!
I am using a cRio 9014 for a remote monitoring application
I have to periodically store data in files in order to read back them using a TCP-IP connection , and store on a remote PC.
File size is about 250K.
I have noticed that after several write operation (about 1000) cRio becomes slow and, finally, stops working.
Using FTP server Data directory results no more accessible (it can be renamed but I cannot access it) . Also the size shown looks small (about the size of one file, 250k).
As I can specify a maximum file number in data directory (my program deletes old files when needed), I have experienced this problem only when file number is greater than 1000 -or about- in the same directory.
Is there any suggestion?
Thank you
Luca Nitopi
(4,141 Views)
Hi Luca,
Are you sure that, after a read function, you close correctly the file's referecences?
Bye
M
Matteo Brunella
Application Engineer
NI Italy
(4,127 Views)
Yes, I do close and, before closing, I flush the file...
Some new trials gives me a lower limit of 500 files.
With up to this number system speed is "normal"
With more than 1200 - 1500 files it looks slower znd slower in saving data
Luca
(4,125 Views)
Hi Luca,
and what about to trasfert datas from cRIO to host PC and stored that datas directly on it?
M
Matteo Brunella
NI Italy
(4,112 Views)
I do transfer data via TCP-IP on a panel PC in order to view and store them (it is a remote monitoring system, I must guarantee several years of data) . The high number of file is needed in order to cover panel pc possible problems (reliability of Windows O.S. and hardware in harsh environmet) . Then it has been asked to me the possibility to use the system as "stand alone" , i.e. to leave it alone for one month or so and then recover data...
In this moment the only way I see is to limit file numbers into a directory and to save them in another for backup...
Data->Data1->Data2->..->DataN until memory is nearly full....
Hi
Luca
Message Edited by Luca Nitopi on 05-28-2009 03:31 AM
(4,109 Views)
Hi Luca,
and what about using NI 9802 module? You can mount 2 memory card and expand you cRIO memory for data storage.
M
Matteo Brunella
NI Italy
(4,093 Views)
