ni 9234
In NI 9234, We are modifying the example VI and trying to create a host application. but in this we are getting only Xand Y direction of sensor direction and not the Z direction and it is not detecting any errors.
version Labview 2010
your help would be apreciated if we could get a response at the earliest.
thanks
(6,118 Views)
Hey Aronium,
it would be helpfully for all forum user to attach the VI, which you have modified.
Which errors are not detected?
Which type of measurement do you try to make?
Stephan
(6,104 Views)
Thanks for the reply.. please find the attached files.
From the acceleration sensor we want to measure in all the 3 direction i.e. x, y, z direction.
But when we tried to modify the program for taking also the z value, the readings are not captured and we are not able to detect.
Could you please suggest what has to be changed in the program so as to accomodate the Z axis for capturing its readings. (3 axis acceleration sensor)IMG_20150511_163159_hdr.jpgIMG_20150511_163159_hdr.jpg
(6,077 Views)
With regard to the above posted question. In NI max the Acceleration sensor is not detected. Please see the attached file.
And please give a feedback on how to solve this issue
thanks
(6,065 Views)
how did you choose the I/O of compactRio?
Thank you.
(5,104 Views)
