issue with deploying modbus TCP I/O server to my RT target a cRIO-9047
Hi
i am having an issue with deploying modbus TCP I/O server to my RT target a cRIO-9047
when I setup an modbus eth I/O server on my cRIO-9047 the SVE stops working and all SV libs and variables disappear in DSC
I experienced this when I was moving my Modbus I/O server from my develop computer to the RT target in labview.
I found out it was the I/O server that make the SVE not working
If I setup a modbus TCP I/O slave server SVE start failing immediately  and any other libs or variables in the I/O server libs stops
If I setup a modbus client like below it only starts failing when connection to a modbus slave server
Below I first create modbus I/O server without specifying an IP address  and the SVE continues running
Then I type in an IP to a running server in this case my computer where I am running an I/O server
I also tried connecting to another Modbus server in a instrument with the same result
modbus TCP between my computer and the instrument with modbus interface works fine
I have been trying to load the cRIO-9047 with both 2023 Q1 and Q3 image  might try a older image also
I try installing whatever modules I could think of that could be relevant for it to work but it keeps failing
I also disable firewall on my computer that did not help
if I program the target from within LabVIEW it is the same issue when I deploy the modbus TCP I/O server
Below the installed modules on my RT target
I tried stopping my modbus slave server and then setting up the client on the RT and then when start the slave server the RT starts failing
And as I mension I cant even start up a slave server on the RT to test it local
It seems like I can setup a modbus RTU slave server without the SVE  fail
i have also seen some fault on the 9047 slot 8 not sure if it related
Is there anything I am overlooking ?  missing software  some firewall or safety setting in the RT target ?
(1,999 Views)
had a go with the 2022 image and labveiw 2022  and it seems like it worked 🙂
not sure if i have installed some missing module while installing 2022 or if there is a bug in labview 2023 or something else
anyway I have made a support request to NI support and i will test it on another cRIO-9047 i have laying around.
(1,975 Views)
What was the outcome of this? I am having the same problem.
Thanks!
(541 Views)
