calculate number of steps and time interval of s curve
I have use Crio 9074 with DIO 9477 to control step motors with NI soft motionAsI know NI soft motion used S-curve to generate trajectory, may someone show me how to calculate the number of steps and time for the trajectory profile with inputs of acceleration (step/s2), velocity (step/s), and position (steps), especially at ramp up sectionI don't know jerk value that NI soft motion uses to computer thisThanks, Hung
(4,238 Views)
I it is not possible to use this module with NI Soft Motion, how have you tried to set this up so far?
Anna K.
(4,222 Views)
Hi, it is running and no problem so far!  I just want to know how I can do hand calculation to determine trajectory profile, velocity vs. time or position vs. time, as I have knows soft motion is implementing S-curve to do trajectory generation.
(4,216 Views)
Could you post a screen shot of your code or describe which VIs you are using?
(4,204 Views)
