 lojius
			lojius
			02-04-2008 08:51 PM
02-06-2008 11:54 AM
Hi Lojius,
Are you using the calibration data? A good reference is the Analog Input - cRIO project in the examples included with LabVIEW.
Do you see an offset with other sources of data as well, or only the sine wave from the signal generator?
03-14-2008 03:52 AM
Hi Jennifer.
Thanks for the reply. I'm using calibration data. Here i attached picture of my code. Hope you can help me to solve this problem.
Thank you.
03-17-2008 03:01 PM
Hi Lojius,
Thanks for the screen shots. The only part I might change is where the calibration data is read in the FPGA VI. The first two frames of the sequence structure can be moved outside of the while loop.
If you haven't already, I would double check the wiring of the 9215. You can find the NI 9215 Operating Instructions and Specifications here. You may also want to try a different slot in the chassis or another NI 9215 or controller if one is available.
What values are you expecting to see? Have you used a voltmeter to verify the output of the signal generator? You can also test your system by running the example program called Analog Input - cRIO, located under Help » Find Examples » Toolkits and Modules » FPGA » CompactRIO » Basic IO.
Hopefully this will help determine the cause of the offset.
03-24-2008 08:51 PM
This is the result of measurement using Basic IO example on LV 8.2. As you can see from the attachment, the offset is still there. I already tried using the other NI-9215 module but result still produce the same result. I attached wiring diagram for reference.
Hope to hear from you again.
03-25-2008 06:06 PM
Hi Lojius,
The wiring diagram you posted seems to match the manual. Have you tested with a different power supply or signal generator? Have you tried using a different slot in the cRIO chassis?
Also, which version of NI-RIO are you using? You can check in Measurement & Automation Explorer under My System » Software » NI-RIO.
