cRIO web server not showing up, but can FTP to it
I am trying to set up the web sever on a cRIO 9004.  I enabled the web server, set the access domain, and then rebooted, but when I try to connect through IE, I get 'This page cannot be displayed'  I can ftp to the rio though, and the LabView web server works as well.
Any ideas?
Chris
(3,351 Views)
Hello Chris,
Since you were careful to set the access domain, you should have permission to connect to the cRio.  As an added test, you could set a star (*) as the access domain so the cRio will give everyone access (to make certain it isn't blocking you).  Since you have ftp access, please check the ni-rt/system/www/ directory and make sure that there is an Index.htm as well as other web pages to test on.  If there is no Index.htm in the www directory, then there really would not be a page to display.  Http and the ip address should be all that is necessary to view the page if it has the Index.htm.
I hope this helps you.
Steven T.
(3,344 Views)
