cRIO variables not updating properly
During the program deveploment the variables work fine now I am triying to run the program to test but the variables do not update properly or not at all.
I am using labview 2011, cRio 9074 with IO's and analog Inputs and Outputs
(5,581 Views)
Could you give us a little more information on what's going on?
1) What do you mean by it works during program development but not when you try to run the program? Are you talking about running it interactively in a project versus as a startup executable? Do you mean you can access them in Distributed System Manager, but not from your VI?
2) What type of variables are you using? Are you using Network Published Shared Variables, I/O Variables, Single Process Variables, or some other type? Are you using the RT FIFO or buffering with any of these variables? What type of data are you passing through these variables?
3) What version of the RIO Drivers and what C series modules are you using?
4) Are you working in Scan Interface Mode or FPGA Mode?
If you can provide this information it will help us help you.
Miles G.
Emerson Test & Measurement Group
Senior System Support Engineer
(5,571 Views)
Hi:
Sorry, but I forgot that I had already posted this question before. I solve my problem.
Thanks for answering.
(5,505 Views)
