cRIO system with WAP-3711
Hello All;
I have a cRIO systemconnected to NI WAP-3711, and I want to transmit and receive data with a host station through the NI WAP-3711. How many NI WAP-3711 do I need to establish this? How is the configuration going to be?
I really appreciate your assistance.
Best Regards.
Tarek
(3,567 Views)
Hello Tarek,
The answer depends on your host station.
  • If your host PC has an integrated wireless Ethernet port, then you need only one WAP-3711 to connect the cRIO to the host through WLAN.
  • If your host station has no WLAN ports, then you need to connect a second WAP-37x1 to it.
In the most common case, WAP-3711 works as a wireless access point that creats connection between your equipment and any WLANs (Wireless Local Area Network); seemingly, that is exactly what you need.
You can also use your WAP-3711 device as a network bridge (connecting two Access Points) or a DHCP server (supporting upto 30 clients).
You have numerous options to configure your network, so I attached a Quick Installation Guide that can help you with that.
You can find more resources in our website:
http://sine.ni.com/nips/nisearchservlet?nistype=psrelcon&nid=203942&lang=US&q=FQL:(locale%3Aen)+AND+...
If you have any unanswered questions left, feel free to ask!
Matyas
(3,551 Views)
