cRIO network data write
I am trying from a cRIO-9040 to perform sensor recordings on a network.
The cRIO is connected to a touch screen and can control a bench and acquire data.
In the code of the cRIO is integrated a dialog box Labview allowing to let the user to select his place of recording. Unfortunately, the dialog box offers me only local folders.
However, I have given as default folder in the dialog box: "\\ ip.ip.ip.ip \ server / folder / subfolder ...".
Since this is a linux OS on the RIO, I also tried: "ip.ip.ip.ip: / server / folder / subfolder ...".
But nothing works!
Should there be a particular configuration of the cRIO or does it require special Labview code?
Thank you for your help !
Message 1 of 1
(1,825 Views)
