cRIO-9075 crashing upon reciept of RS-232 message
I am working on an application for a cRIO-9075 and the cRIO crashes when it recieves a RS-232 message.  Based on the CPU usage chart in the DSM it doesn't seem to be overloading the processor but if I disable the main For Loop in the program that recieves the RS-232 data the cRIO doesn't crash.  When the cRIO crashes the program briefly freezes and then on my development machine I get a message that the connection to the cRIO has been lost.  The RS-232 messages are only 20-30 characters and the For Loop is really doing anything complicated.  Any ideas would be appreciated at this point.  I'm running Labview 2012 SP1 on the development machine and NI-RIO 12.1 on the cRIO.
(4,178 Views)
It's pretty unlikely that reading from a serial port will do that. Are you using the built in port or a 4-port module? I actually had something like a dozen 9075s operating a modbus network from the built in serial port, using LVRT2012. It probably not a bug in the actual VISA port operations . Post a screenshot or snippet of that for loop with the serial read in it, as well as how the port is being initialized, that will help.
(4,158 Views)
