build fuzzy logic controller on compactrio
I have built a CompactRio LV FPGA Project to acquire 3 AI and pass these signal to Host for generating AO.
I have build Fuzzy Logic controller using FL design in Control Design and simulation.
The problem is I cannot able to make the correct file path of .fs using FL load to my target
Is there any solutuion to that or any tutorial for Fuzzy Logic in real time control
Just found on LV examples some FL VI vot FL project using Compactrio
(6,160 Views)
Could you explain the problem a little further? Possibly attach a screen shot?
If you are looking for examples the code exchange is a good place to look; ni.com/code.
As far as tutorials for Fuzzy Logic, this is a link to the manual:
https://www.ni.com/docs/en-US/bundle/372192d/resource/372192d.pdf
James
(6,112 Views)
Do you mean that you are not able to transfer .fs file to your rt controller?? Because otherwise you will need to use load fuzzy controller vi from control system and simulation. You can attach .fs file there. If you want to transfer your .fs file to rt controller, follow instructions given in forum...http://forums.ni.com/t5/LabVIEW/Problem-of-using-fuzzy-in-my-project/m-p/1772362#M615631..
PLZ Check that it is suited for application.
(5,996 Views)
