'You are trying to start an interface that is missing bus power for the transceiver'
I am getting this error whenever I try to start taking a measurement in NI MAX for my NI 9862 module. I added a 120 Ohm resistance according to the pin allocation in the documentation and I have an external power connected with the module so I am not sure where the problem lies.
I took pictures of my connections and attached them to my post. The external power is coming from the board and I added a 110+11 Ohm resistors to the socket.
(2,280 Views)
Hi, did you manage to solve this issue?
I have my NI-9862 card connected to cDAQ-9185 which is plugged to 230V socket. Voltage is then reduced to 12V, within the specified range for both cDAQ and NI card.
I'm currently stuck on the same error.
(713 Views)
