Xilinx tool for ISE 14.7 stuck at Translating
Hi
I am using LabVIEW 2018 SP1 and  FPGA module with cRIO9076. When I try to compile the fpga vi the xilinx compiler stuck at Translating for hours with no error. I also tried a very simple vi to test the behaviour . I am using Windows 10 32 bit. can you please  point me out to possible cause of that behaviour. is there a compatibility issue?
(2,698 Views)
(2,667 Views)
Thanks for the link I have not used the cloud service , I'll give that a try .
(2,662 Views)
I would recommend the Compile Cloud Service as well. Any of the Xilinx Compilation Tools for ISE are not supported on Windows 10, but the Vivado tools are. Here's a great article (with a flow chart!) on compatibility with Windows 10. Your behavior is likely being caused by the unsupported configuration.
LabVIEW FPGA Module Compatibility with Windows 10:https://www.ni.com/en/support/documentation/compatibility/17/labview-fpga-module-compatibility-with-...
Hope that helps you get moving on your compilation, and helps you understand why the software was getting stuck!
(2,625 Views)
