Wrong time stamp on cRIO real time controller
I am acquiring data from thermocouples using cRIO (RT controller - NI cRIO 9025) and I want to include a time stamp in my file's metadata to know when the measurements are taken. The date is right but the time value return by the 'Get Data/Time in second' is wrong. I think it comes from the time of the cRIO as I got similar time for TDMS files creation when I download the file from 'ftp://IP'.
I have up dated all the software and set the time zone from MAX again, but it made no difference.
All the similar post I have found are about time zone settings, but I don't think it is a time zone problem since the difference is around 4h27 (the value seam to vary from +/- 15 s). Any idea on what is going on?
I am using Labveiw 13 and NI cRIO 13.0.
Thank you for any help you can provide
(5,637 Views)
Hi stn111,
Have you tried using the Get & Set Time.vi example? You can find it from the Example Finder>Hardware Input and Output>System Configuration.
Al C
National Instruments,
Application Engineer
(5,616 Views)
Thank for the answer AI.C, I ran the VI and it works much better now.
However I still have a 12s lag comming from the time difference between setting the time and running the VI. It is good enought for the purpos of knowing when I did my experiment but in the future I will need to integrat my measurements in a data base with measurements comming from other soucres and I would like the time stamp to be syncronize with my computer. Is there an easy fix for that?
I guess I could add those 12s to the time stamp in my LABView code, but I would prefer something less patchy.
Many thanks
(5,604 Views)
