Wiring NI9208
Hi All,
I am currently trying to measure pressure using a Wika R1 pressure transducer.
I am using NI9028 with DSUB Terminal Pinout.
There is existing equipment already, so I am wiring into terminal 22 and terminal 14.
I am current not getting any put reading to LabVIEW.
Am I reading the wiring diagram wrong or is there an other issue?
(66 Views)
Did you connect an external power supply?
You need to wire correctly, depending on your sensor type.
Reference: NI 9208 Getting Started Guide
https://tmesystems.net/
(61 Views)
I am currently wiring into an existing board that measures pressures in other tests.
The previous employees have soldered on to the pins so I carried out the same procedure.
The Wika R1 is a two cable pressure transducer one goes to the 24V (pin 22 new solder) and signal to pin 17 AI14 (existing wire).
I did have it connected to another pin at one point which was giving out a 10-7 number.
(42 Views)
