Wirelss Data Measurement on cRIO
I need to measure a few voltages wirelessly using LabVIEW on the cRIO 9073, independent of web access. I am not too familiar with LabVIEW, so could someone give me perhaps a general outline of how to go about doing this? Or direct me to some applicable tutorials or help pages? I have already been through many of the basic LabVIEW tutorials and posts in this forum but post whatever you think could help.
Thank you
JKF
(5,472 Views)
I forgot to add, I need to be able to view the measurements in real time through a browser on the same network as the cRIO.
(5,465 Views)
Take a look at these threads:
http://forums.ni.com/t5/Real-Time-Measurement-and/cRio-and-router-access-point/m-p/1215939
http://forums.ni.com/t5/Real-Time-Measurement-and/Making-cRIO-9014-Wireless/m-p/1213179
Essentially, you can plug your cRIO into an access point that will connect to your normal wireless network. That will get you on the same network as other machines and you can then use remote front panels or web services to publish your data through a browser.
Alex Person
NI-RIO Product Support Engineer
(5,457 Views)
Okay, thanks for your reply. So can I use a web service on a local network without internet access?
(5,431 Views)
Yes, the CompactRIO will actually have the server running for you to pull data from. So as long as you have a connection to it, you should be fine.
Alex Person
(5,429 Views)
