What Module will be best for Thermistor usage
The system I need has to measure between 8 Channels and 16 Channels from a temperature block.
The spec is very low as I need to measure with an accuracy of 0.2C or less. I was looking at the some of the temp modules cDAQ and will probably try the NI 9226. However the only issues I have is that I will need to use a regular sensor. Will this module work with a Thermistor?
Also are can I use an analog module with a Thermistor to get more channels?
I also have to say that I cant use tick wires and the reason I am looking at thermistors is because a flex pcb will be best for this application.
Thank you in advance.
(3,022 Views)
NI doesn't have a module specifically for measuring thermistors, but there are some modules that may work depending on the specs of your thermistor. I'd recommend reading through the different options described in Thermistor Measurements With the NI-9219 and Other C Series Modules.
-Jordan
(2,966 Views)
