Watchdog cannot be deployed on c-RIO target
Hello everyone,
I'm not able to deploy vi containing watchdog to c-RIO 9042 Linux RT System Image 2025 Q1.
As soon as I try to deploy my RT VI I gor the following error:
Deploying Watchdog Add Reset Action.viWatchdog Add Reset Action.vi loaded with errors on the target and was closed.
At first I thought it was my mistake in implementing the watchdog, that was very possible, being this first time for me to implement this feature in a cRIO RTvi.
I then tried to open the NI example project from my installed library, which I expect to properly work.
But also with that I wasn't able to deploy a watchdog to my cRIO, error received during deploy:
Deploying Watchdog Acknowledge.viWatchdog Acknowledge.vi loaded with errors on the target and was closed.
Again issues in deploying watchdog library components.
The following software is installed on mi cRIO:
Any suggestion for solving this issue?
Thank you in advance to any contributors.
Franco
(575 Views)
Accepted by topic author francoazzano
Hello everyone,
I solved it in the most logic way.
I found the NI Watchdog package available from the Add/Remove Software feature of the MAX under my Target:
A just added and issue was solved.
Sorry if I was too hasty in opening the post.
I hope this helps someone anyway.
WBR,
Franco
(567 Views)
