03-30-2011 05:26 AM
Hi;
I have a closed loop control system using Fuzzy Logic as a controller, by using the CD parametric time response "in Control and Simulation Module" I found the overshoot and rise time and other parameters for the open loop.
Now I want to use the same vi or any other vi to find closed loop parameters.
Can anyone help?
Regards
Bakhtiar
04-04-2011 08:35 AM
Hi Bakhtiar,
Thank you for posting on our forums, I am currently looking into this query for you.
By any chance could you attach your code for me to look at?
Many Thanks,
04-05-2011 06:20 AM
Hi;
Please find attached the code, I want to determine the closed loop parameters such as overshoot and rise time using CD parametric time response.vi or any other possible techniques.
Regards
04-11-2011 04:15 AM
To determine overshoot or rise time values you will need the Jitter analysis toolkit as there is a handy vi called 'Overshoot and Undershoot.vi'
Details can be found here: http://zone.ni.com/reference/en-XX/help/373270A-01/lvjitterphtk/overshoot_and_undershoot/
