Thermocouple and Superlogics 8520 & 8018
Hi all,
I'm a new LabVIEW user and I try to measure a temperature using a thermocouple and superlogics 8520 (as RS-232 to RS-485 converter) and a superlogics 8018 (8 channel thermocouple input module). When I use the DAQ assistant I have this message ''no supported devices found''. I downloaded the drivers from superlogics and tested all the connections but I still don't know why my computer don't detect my device. Probably I missed a step?
Jamat
(3,544 Views)
Hi Jamat,
The DAQ assistant only supports devices that run on the NI-DAQmx driver which are the NI DAQ cards.  I can see that the products you have are connected to the PC through RS-232.  Usually you would use serial commands to talk to this.  Superlogics have done the hard work for you though and have drivers available on their website at http://www.superlogics.com/downloads.asp?prod=787.  If you download and install these you can use their LabVIEW functions to acquire data from the device but these still will not work with the DAQ assistant.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(3,535 Views)
