System Identification Labview or Matlab???
HI ,  I would like  you to recommend me  a website or some manuals  where I can find some information about the difference between  MAtlab  system identification  and labview system identication , if there is any??? everything about this would help . At the moment I trying to work in a plant  I used to control with matlab , but now I want to control it with  LABVIEW , and I would like to know the differences about working with these 2 softwares ...........I am looking forward for your anwsers ...... Smiley Happy
Hola que tal , quisiera que por favor me recomienden algun sitio  o alguna informaciòn donde pueda leer cual es la diferencia entre el system identification de Matlab y el de Labview , si es que existe alguna diferencia ?????? todo lo referente a eso es de mucha ayuda , ya que estoy implementando una palnta que anteriormente estab implementada con matlab , ahora con labview , y quisiera saber cuales son las diferencias de trabajar con uno u otro software , por favor espero su resppuesta !!!!!Smiley Happy
(5,066 Views)
Jen1,
I can't tell you the difference between both products, but I can appoint where you can find information about the System Identification Toolkit for LabVIEW. If you go to our website and search for Manuals about System Identification, here is what you will find:
In LabVIEW, if you are trying to control a system, you would be better to have the Control Design and Simulation Module available for LabVIEW. They allow you to analyze the plant obtained with System Identification and develop and implement a controller. Here is the documentation for these products:
Let me know if you have some specific questions.
Barp - Control, Simulation, RTT and HIL - National Instruments
(5,064 Views)
Thank you for help . I have an specific question , does labview use the same algorithms to identify a system that matlab , or are they different ???
(5,057 Views)
In the LabVIEW you can use MathScript that has the same function of the MatLab and to have this tool it does not have no additional cost.
(5,043 Views)
Hi Jen1
  On the manual (Alex put the link above) you have the algorithms implemented in the tool that can be used. You can also implement your own algorithm as templates are provided.
Hope this helps
(5,031 Views)
Thank you for your help Smiley Wink
(5,022 Views)
