Synchronization using timestamp
Hi everyone,
 I'm using 9205 module with 9191 chassis (wireless) and also use 9401 module with 9171 chassis (USB).
I need to synchronize between them, and understand that it's not possible since they are independent
My question is, if I can use the initial timestamp which always appear in the TDMS root file. (in the excel), for knowing when the modules acquire data at the same time. (I use the same sampling rate for both modules).
Reut
(2,351 Views)
Accepted by topic author Gutenberg
That won't be exact because each unit is going to have its own timing clock which will drift past each other.
(2,317 Views)
Thanks, the information in the link helps
(2,298 Views)
