Some strange noise when I use NI 5761
Hi all,
I try to acquire analog data using NI 5761 and PXI-7952R and I use NI 5761- Getting Started example to acquire the signal
from function generator. But when giving a sinewave (15MHz,-300mV~300mV) from an function generator, sometime the reslut have some strange noise.The signal had been checked by Oscilloscope and I I think there is something wrong when analog  to digital. I have attached the screenshot of the error.
Any help would be deeply appreciated. Thanks.
(3,114 Views)
Accepted by topic author fn250250
That looks like glitching. Make sure you the analog input node is being accessed inside a single cycle timed loop that is using the clock exported by the CLIP. The getting started example for that IO Module should demonstrate how to do this.
(3,050 Views)
You're right. I change time loop clock from 100MHz to data clock. Now the problem is solved.
Thank you very much.
(3,036 Views)
