SBRIO 9629 running hot and analog inputs not working, cannot connect in DAQmx mode after driver upgrade
Background:
Running LV2020 + RT/FPGA suite 20.5.  I have been using this board for development for about a year now.
The project is for real time control and data acquisition for our different valves (which have analog or SENT sensor outputs).
It's been sitting at my work desk on mounting screws connected to an  interface board through the breakout board that I got with the Dev KIt.
The interface board has a DC Motor driver, signal conditioning circuits (i.e. J2716 SENT interface), signal selection relays,...etc
The SBRIO was working perfectly fine until recently.
The project is relatively mature with all functions implemented.
Issue #1: Board running hot (I think)  and analog inputs not working
Recently the sbRIO has been getting up to 60degC.
If I start from a cold with no test software running (room temp start from powered off), the board reaches 60degC within a couple mins.
It will run ~30% CPU load without anything test software running.
But I didn't really pay attention to the temp/CPU load with no test software running  before, so I don't know if this is abnormal.
Along with this noted behavior, all the analog inputs now do not work correctly.
--> Some of the inputs seemed to be mapped incorrectly (note, wiring was not changed) --> i.e. one channel's voltage reading show up on another channel.
--> Many of the other SBRIO analog inputs are behaving like an analog 0V output: if I connect them to the interface board which has filtered analog outputs, these SBRIO analog inputs drag the voltage level down to 0V.
-->The status light is normal (not on), green power light OK.
--> Nothing else abnormal is reported in MAX
The digital input/outputs  and everything else appear to work OK (i.e. I can run closed loop control of valves with digital SENT output).
I don't believe this is a PC software or driver issue issue, as I have a CRIO 9056 that runs the same project without issue.
That CRIO also connects to an identical custom interface board.
Anyway, I have another  9629 I could use that is going to be installed in the formal test stand soon (to confirm it's a hardware failure), but I wanted to get some ideas what might be causing this...
Issue #2:  Cannot connect in DAQMX mode after upgrading DAQmx and downgrading
Unfortunately, I'm unable to connect in DAQ MX mode to check the analog inputs this way.
This is because I installed LV 2023 for another project, which installed DAQ MX 2023.
When I tried to connect I get a DAQ MX version mismatch error (as the SBRIO has DAQMX 20.1).
I uninstalled DAQ MX 2023, rebooted, reinstalled DAQ MX 20.1 on my PC.
However, the issue persists: when I tried to connect in DAQ MX mode, I get a version mismatch error despite 20.1 installed on PC and SBRIO/CRIO.
I tried uninstalling DAQ MX 20.1 from the SBRIO and CRIO.
Now, when I try to reinstall DAQ MX 20.1 from my PC onto the device, it shows that I do not have V20.1 at all available (even though I clearly do, and it shows up in Package Manager).
Any tips would be most welcome!
Thanks.
Matt Lawson
Test Engineer
(498 Views)
Note I had the model number wrong it’s SbRIO 9638 with the 28 built in analog inputs
(483 Views)
Hi Matt,
For both your issues, I would want to determine if the issues are related to the software or the hardware.  For issue #1, it sounds like the sbRIO is running hot for no reason.  Try formatting it to erase all software, and re-install the RIO software on the sbRIO.  Don't deploy your RTEXE yet.  Power it on without any programs running, and observe its temperature.  If the temp is 50-60 degrees, there might be something odd going on.  If no symptoms, great, deploy and run your RTEXE, and observe again.
For issue #2, formatting the sbRIO and starting over usually does the trick for me.
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
(438 Views)
Thanks John, I will try out your suggestions this week and get back to you.
Best Regards,
Matt
(420 Views)
Really late reply...
The sbRIO sas a 9638, not a 9629 (another project).
Anyway, the single channel that was swapped was a harness issue.
The rest of the remaining AI channels acting as outputs of 0V was a software issue.
Reformatting the target, reinstalling the base software and then redeploying the application software resolved the issue.
I suspect some physical mapping address or configuration to the Analog inputs must have been corrupted.
CPU usage / temperature was no longer a problem after reformat as well.
Thanks!
Matt Lawson
(251 Views)
