03-29-2021 03:11 PM
My team recently purchased a PCIe 7846R card. I have found on the NI website there are two differing pinout specifications for this card that conflict.
On the PCIe 7846 R-series card documentation proper, I see on page 2 that connector 1 has a particular pinout, ex. pin 1 is DIO31.
https://www.ni.com/pdf/manuals/378050a_03.pdf
Conversely, on the more generic documentation for the PCIe 784xR, I see in Figure 2 on page 10 that connector 1 has an entirely different pinout, ex. pin 1 is +5V.
https://www.ni.com/pdf/manuals/372492c.pdf
Which, if either, of these pieces of documentation has the correct pinout?
Solved! Go to Solution.
04-05-2021 06:59 AM
You are right, there is discrepancy in the documentation - Please use this https://www.ni.com/pdf/manuals/378050a_03.pdf ( as this is the latest pin out document - last document updated in Nov 2018)
Looks known an issue documentation. Remember that the Connector 0 should be (DIO) and Connector 1 (MIO). To resolve please switch both the pin-out pictures and the (MIO/DIO) text from the above link.
Dharani | CLA | CTD
