NI 9870 module
these VIs are from the example in LV
Message 11 of 32
(3,448 Views)
moonm,
I'm guessing that typedefd control named 901x DMA FPGA Reference.ctl  is not properly referenced to the FPGA.
Message 12 of 32
(3,440 Views)
Hi
I don't understand your response
Can you explain more
regards
Message 13 of 32
(3,434 Views)
When you run a cRIO in FPGA or Hybrid mode, you have two vi's running.  One ( Host ) runs on the real time OS.  The second ( Target ) runs on the FPGA.  The 'Host' needs a reference to the 'Target' vi.
This example project was set up with 901x DMA FPGA Reference.ctl  as a typedefd custom control referenced to the 'Target' vi running on the example FPGA.  You need to open up 901x DMA FPGA Reference.ctl and make sure that it is reference to your 'Target' vi.
Message 14 of 32
(3,429 Views)
These files in my project i moved them from the example that ships with LV to my project.
When i open the 901x DMA FPGA Reference.ctl how can i make sure that it is reference to my 'Target' vi ??
Message 15 of 32
(3,425 Views)
'Right Click' on the reference and select  'Configure FPGA Reference'.
Message 16 of 32
(3,423 Views)
Hi
I open up 901x DMA FPGA Reference.ctl and it is reference to my 'Target' vi.
Message 17 of 32
(3,412 Views)
For example, when i open the "Serial Loopback DMA (Host).vi" in my project :
Message 18 of 32
(3,411 Views)
I have this errors list when i want to run :
Message 19 of 32
(3,408 Views)
Did you recompile you FPGA target vi after you moved things around?
Message 20 of 32
(3,401 Views)
