Hi Steve,
I'm not sure what you are refering to when you mentioned "refresh AI setting update with the required values".
Are you talking about AI calibration? Or is it some kind of custom FPGA code that takes input to specify the rate of your acquisition?
Did you have an example to work off of? Are you using a pre compiled bit files?
What would you like to set on the FPGA program? What settings are you passing onto the AI?
Please clarify. Thank you!
Yi Y.
http://www.ni.com/support
