Labview FPGA compile error
I am using Labview 8.6.1 FPGA module to program sbRIO 9632. I have written one program to access FPGA I/O. I was able to run the program few times. Initially FPGA compile server was taking 45 minutes to complie. After some compilations , it began to take more that 2-3 hours to compile same program ( I aborted the compilation after 2.5 hrs). Then I repaired the FPGA module. After that if I try to run any FPGA program ( even very simple programs) it is giving following error and aborting the program. ========================================================================= * HDL Analysis * ========================================================================= Analyzing Entity in library (Architecture ). FATAL_ERROR:XdmHelpers:Xdh_PropFiltImp.c:499:1.34 - Unable to locate property filter file ucf.pfd. Process will terminate. For more information on this error, please consult the Answers Database or open a WebCase with this project attached at http://www.xilinx.com/support. ERROR:Xflow - Program xst returned error code 2. Aborting flow execution...
(4,403 Views)
I know you just repaired your installation, but that appears to be an installation issue.  Try removing and reinstalling the LabVIEW FPGA compile server.
(4,387 Views)
Thanks. I reinstalled FPGA module , compile server and Xilinx tools and now it is working fine.
(4,372 Views)
Hi mlkarle,
It is a good practice to mark the post as 'accepted solution' once you have found your answer.
Mithilesh Pradhan
(4,359 Views)
