LV 2014 (with FPGA Module) runs out of memory while opening/saving a VI
Hello All,
Here is my problem in a nutshell:
When I try to open a SubVI that I have created, LabView runs out of memory and crashes. My system specs are below:
- LabView 2014 32 bit
- LabView Real-Time and FPGA Modules Installed (2014)
- NI RIO 14.0 Installed
- Windows 7 (64 bit)
- 32GB of RAM on my computer
I look at resource manager in Windows, and see that while LabView opens the VI, it uses up to 3.9GB of memory before crashing (since it is a 32 bit version of LabView, I am limited to ~4G of virtual memory). The same problem occurs when I try to: a) generate intermediate files, and b) Build the top level VI.
I suspect this problem is due to the fact that the top level VI has SubVIs that are kind of large (there are 5 SubVIs that are between 250 and 520 kilobytes each). The .lvproj file is 17.8MB in size, largely due to the fact that it uses a large number of memory items and registers. Unfortunately (for reasons I will elaborate on later if anybody is interested), I cannot reduce the number of register or memory items used in the project. But having said that, I cannot imagine why LabView needs more than 4GB of virtual memory to perform these operations (open/save the VI, generate intermediate files, etc). Any pointers would be greatle appreciated. Thanks!
Best,
Aditya
(5,564 Views)
Hi Aditya,
Does this happen with other LabVIEW projects? Would it be possible for us to see a screenshot of the error you receive before LabVIEW crashes?
Jordan G.
LabVIEW Product Marketing Engineer
(5,529 Views)
Hello Jordan,
Thanks for your reply. No, this crash does not occur with smaller LV projects. The FPGA target is configured with a large number (1914) or U64 registers. This VI essentially has 33 cases in a case structure. Each case reads 58 unique register items and outputs a cluster of size 58. Obviously, 33x58 = 1914. I can explain the reasons for this weird implementation if you are interested. Before the crash, LV uses about 200MB if memory. At the time of the crash, it is ~4GB.
I've attached two screenshots:
a) before crash, and b) after_crash.
Please let me know if you need any other details. Thanks again.
Best,
Aditya
(5,520 Views)
Hi Aditya,
Is this a fresh install or an upgrade of LabVIEW 2014?
Jordan G.
(5,490 Views)
