Input mode for NI-9205
I am building my first datalogging application with cRIO and two sensors.  My question is two-fold.  The first is a wiring question and the second is a question bout COM vs AI SENSE.
First of all, I have two different types of sensors.  The first only has two wires (floating) and the other has three wires (ground referenced).  I would like to wire these in the most intelegent way.  Do I need to take a differential measurement of the ground references sensor?? If so, where should I locate the ground for this sensor.  Likewise, if I am taking a single ended measurement of the floating sensor, what do I ground reference the other sensor.  I hope my question is not too confusing.
Secondly, I would like to take several NRSE measurements of all the sensors, (floating or not) but I am not sure if this is possible.  I have seen wireing diagrams in the operating instructions and specifications document of the 9205.  Am I unsure what the difference is between the COM and AI SENSE modules of the 9205.  Any help here would be greatly appreciated.
(5,675 Views)
Looks like you have seen the operating manual - which is usually a good place to start for typical wiring diagrams. I think if you read this Field Wiring White Paper - that might shed some more light for you. Regarding the AI-SENSE input it makes the following statement which perhaps answers your second question:
"In an NRSE measurement system, all measurements are still made with respect to a single-node Analog Input Sense (AI SENSE), but the potential at this node can vary with respect to the measurement system ground (AI GND)"
Consultant Control Engineer
www-isc-ltd.com
(5,667 Views)
