How to programmatically deploy target vi or exe from host exe
I have ran the 'new RT project' wizard to creat a simple app. that talks from a target PXI chassis thru the network using is shared variables to my desktop. It all work fine when I deploy manually each .vi and run it.
What would be the correct setup to automate the host vi to call target vi ( and its support vi ) without using the project manager?
THanks!Robot Happy
(3,604 Views)
Hello Cortes,
You can programmatically call any VI on a remote computer as long as the VI Server is configured to allow the connection from your IP Address and if it allows a connection to the VI you are trying to call.  You can then deploy an executable to the Real-Time system.  If it is not a configured as a start-up executable, you can run it using the VI Server.
Here is a link to an example program that runs a VI stored in an executable on the hard drive of the Real-Time system.
http://sine.ni.com/apps/utf8/niepd_web_display.display_epd4?p_guid=B45EACE3E2AF56A4E034080020E74861
I hope this helps you.  If you have specific questions about this process, the LabVIEW help has some resources and you can always ask us here at the forum.
Steven T.
(3,596 Views)
