How do I pass control values for a spawned process via vi server?
I'm creating a LabVIEW Real Time application.  I'd like to use VI Server to spawn off a process without waiting for it to finish.  My understanding is I can't set control values via vi server in my built application for real time.  How do I pass specific values to the process I'm spawning?  Please note I may be spawning the same vi several times immediately, so using some sort of global will have some handshake issues.
Thanks!
(3,581 Views)
mikemattball,
You are correct that the VI Server methods will not work, because your VIs don't have front panels once they are built for real-time. You will need to use another form of interprocess communication such as queues or notifiers.
Is there a need for spawning of VIs in your application or are you just trying to follow the same design patterns you use on the desktop?
The CompactRIO Developers Guide (http://www.ni.com/compactriodevguide/) walks through typical architectures for real-time applications.
Kurt
(3,565 Views)
Kurt,
Thanks for the reply.  I need to spawn as part of the application startup.  I have processes that kick off at the beginning.  I understand the concern over spawning since it's not a real time architecture, but this portion of the code isn't critical.
I'll take a look at the linked page and see if I can find a solution.  It sounds like I'll need to manually handshake it.
Mike
(3,561 Views)
