How can I find that the i/o used in the VI connected to which pin of FPGA chip ?
I am using the FPGA module 8.5 with cRIO-9074. Can I know that the inputs and outputs used in the VI, connected to which pin of FPGA chip?
(3,928 Views)
Can you elaborate on this? What exactly are you trying to do?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,923 Views)
Other softwares used for programing FPGA creats a constrain file which shows the variables used in the program as input and putput connected to which i/p pin of the FPGA chip.
As an example if there is A,B,C three variables as input and a variable D as output then the constrain file shows that at which i/o pin of FPGA chip these variables are assign.
As   A-11 pin to A
       A-12 pin to B
       A-13 pin to C
       A-25 pin to D
I want to know that does LabVIEW provide this type of facility.
(3,897 Views)
LabVIEW FPGA does not provide this specific feature as it is a higher level design and programming tool than the software tools you are comparing it to.
LabVIEW FPGA and the RIO platform (R series, CompactRIO, SingleBoard RIO) define all of it's I/O through resources in the LabVIEW project. So in effect, yes, you can see the I/O defined for your solution using the LabVIEW project. In your LabVIEW FPGA VI diagram you connect your "variables", which are the wires, to the I/O using the I/O node. You define the association of data in the diagram to the physical I/O that you have access to on the hardware.
Look at some of the basic DIO examples that are installed with LabVIEW FPGA and NI-RIO to see how this is accomplished.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,882 Views)
This image shows the LabVIEW FPGA project and an example FPGA VI diagram that illustrate how you can define your I/O (InputA, InputB, InputC, OutputD) and how to access the I/O in your VI to perform different operations on the input and pass the result to the output.
LabVIEW FPGA project and VI diagram
Message Edited by Christian L on 05-07-2009 10:06 AM
authored by
Christian L, CLA
NI - Austin, TX
(3,881 Views)
