11-16-2012 04:00 AM
I am relatively new in labVIEW and the NI hardware products. I have a PXIe 1075 with a 8133 controller, 7965R FlexRIO and a 5665 RFSA. I would like to acquire some IQ samples with the 5665 cards and send then to the Flex RIO by a peer to peer channel. Then the FlexRIO will compute an FFT an send the result to the Host.
I have based my VIs on differents LabVIEW examples but it still does'nt work. The peer to peer FIFO RFSA2RIO in the FlexRIO stays deseperately empty. The channel is enabled but no IQ samples seems to be sent accross the linked. It seems to me that the problem comes from the RFSA because the access leds are not amber. So I think that no acquisition is done at all. Would somebody have an idea why the RFSA doesn't work? (bad config? forgot something?)
Thanks in advance.
Stephanie
11-16-2012 09:15 AM
I would like to add some details. In fact, the problem does'nt come from the NI RFSA as I supposed first. I set the IQ rate at the maximum value and increased the delay in the while loop in my VI running on the Host.
After all, I have some IQ samples in the RFS2RIO FIFO (and led of the digitizer becomes amber). I have still a problem to de-multiplex the I and Q sample towards two differents FIFO (FIFO_IN_I and FIFO_OUT_Q).
11-21-2012 05:09 AM
Hello Stephanie,
Sorry for the delay, I am taking in consideration your issue. I will try to answer you as soon as possible.
MatthieuR
Matthieu RICORD
National Instruments France
Été de LabVIEW 2014
12 présentations en ligne, du 30 juin au 18 juillet
11-22-2012 02:59 AM
Here is an example "Peer-to-Peer (P2P) NI RF Signal Analyzer to FPGA Module"
Attached example shows the latest National Instruments functionality called peer-to-peer (P2P) streaming between the NI PXIe-5663 and the NI PXIe-7965R. This example requires NI-RIO 3.3 or later and the NI-RFSA driver. The example shows how to provide the data being streamed from the NI PXIe-5663 to the NI PXIe-7965 for processing.
The code is well described.
I hope it will help.
MatthieuR
Matthieu RICORD
Été de LabVIEW 2014
11-22-2012 03:02 AM
Matthieu RICORD
Été de LabVIEW 2014
11-23-2012 02:45 AM
