Fixed point to Dynamic data
Hi
I am using cRIO Module.
I am taking input from one of the cRIO's Analog Input Channels, on the fpga target
And then importing these values to RT module for signal processing.
However when i am connecting one of the imported channels to a filter,it shows an error stating " the source is fixed point number and the sink is dynamic data type"
How to carry out this conversion?
Message 1 of 10
(4,774 Views)
You don't.  Use one of the actual Filter VIs instead of one of the Express VIs.  Look in the Signal Processing->Filters palette.
Message 2 of 10
(4,773 Views)
How do you get down from an elephant?
Jim
Message 3 of 10
(4,760 Views)
what do you mean?
If someone asks for help, you help him JIM.
Message 4 of 10
(4,743 Views)
@Crossrulz,
i also need to use tone measurement which isnt available
Message 5 of 10
(4,742 Views)
And,
only point by point filter works..
how is it different from normal filter?
Message 6 of 10
(4,739 Views)
@Bgmnt wrote:
And,
You would actually be having the same issue with the dynamic data version since you only have a single point.
Need more information here: What is your sample rate?  How are you transfering the data from the FPGA to the RT?  Code could especially be useful here.
Message 7 of 10
(4,731 Views)
I havent really set up the sampling rate anywhere but my signal belongs to 0- 20 Hz.
I am sending the data using FIFO
Message 8 of 10
(4,721 Views)
Sampling rate will be determined by your FPGA loop rate.
Another thought here: you should probably do your filtering in the FPGA.  It can handle the math a lot better than the Real-Time and it would help avoid some of this confusion.
Message 9 of 10
(4,718 Views)
tone measurement isnt available in fpga toolbox
Message 10 of 10
(4,692 Views)
