Error 1003 when loading a VI dynamically on LabView Real-time
I created a SubVI that is opened at runtime via "open VI reference" on my LabView RT system. This works well except for the case when using a simulation loop. Error 1003 is reported, i. e. the runtime system can not find some SubVIs. This error does not occur when using a simple "Gain VI", but it does occur when using an integrator function.
It did install the Control Design and Simulation Toolkit 9.0 on my real-time system. For more information see attachment. I did also create a screenshot of the simulation loop VI which is loaded at runtime.
(3,857 Views)
Hi
When you´re working with VI references you have always to include this VI into the build.
Error 1003 or 1124 When Using VI Server To Call a VI on a Real-Time Target
Why Do I Get an Error When I Run My VI On My Real-Time Engine Remotely Using VI Server?
Kind regards
Pixar
(3,841 Views)
